Hi Guys'
The 'Appropriate Code' in this case is that published by the 'Southern Federation of Model engineering Societies'
and is the code to which RGY's club supposedly adheres.
Section 4.1 of this code clearly states that in the case of a new (unpublished) design then providing that the constructor produces a full set of drawings and the necessary mathematical calculations to submit to the inspector for approval, and providing that these support/verify the integrity of the design than there should be no viable reason for your club inspector to not provide a test and certificate.
Sadly, we are faced with a lot of 'supposed' experts in many clubs, who wear the testers/inspectors hat, and most are not capable of verifying the calculations.... in my mind such people should not be in the position.
RGY... if your boiler is of no greater capacity than 3 bar/litres, then under the same code you are exempt from all test requirements. (see ** below)
If, on the other hand, it is only a matter of insurance (which I would find odd, since any club using that code should have the appropriate insurance to permit it's use) then you can easily obtain insurance from 'Walker Midgley Ltd' or from any 'Royal and Sun Alliance' brokers, since these insurers were part of the team which developed and agreed the code in the first place. All will deal with individual applications, not just clubs.
There is no need to go to all the trouble and expense of getting your design verified by an outside authority.
Most of these would be following the same code anyway, or the original 'PRESSURE EQUIPMENT REGULATIONS 1999 SI NO. 1999/2001 ("PER") P.E.D.97/23/EC' code from which it was derived, and the same design verification rules apply.
** You may still need to get a steam test done under club rules, but this is not the same thing as a full pressure test, since no Hydraulic testing is required, but rather verifies that your safety valve, water gauge and other fittings etc are fully functional and that no pipe work leaks are present. This is done at normal working pressure.
Again, if the boiler is built to the code, then there should be no valid reason to refuse such a test.
Best regards.
SandyC
