jlmanatee said:
Another lurker here. I thought I'd jump in again.
I have a situation and want to know if this happens to you all too. I start a project, then find that I need to make some tool for the project, then find I need to make an improvement to the mill or lathe before I can make the tool, then find I need to make a fixture for the improvement before I can use the mill or lathe, then ................
Pretty soon I'm months behind on the project. Heck, I can't even remember what the project was. Don't get me wrong, I'm having fun. But I find it ironic.
- Jack
Some of that is unavoidable but it's important to take note of your personal psychology when you encounter it.
For most people, motivation is most inflated by completing something. If a project languishes too long, there's a very good chance it will never be completed. The resulting effect on the psyche is not good. The project does not need to be perfect (or made in perfect adherence to established shop protocol) to be satisfying and motivational.
I keep two project lists. One is actual engines and models I want to build and the other is production items - tools, jigs, fixtures and tool mods that will help to make future tasks easier or more accurate.
While building a model, I will divert to make a tool or jig that is *essential* to the job but, before doing that, I will try hard to "work around" the absence of the item, put it on my second project list, and just soldier on. (Actually, "working around" can be as creatively satisfying as making the missing item.)
Since I build mostly small models, when one is finished I'm ready for some less finicky work before I go back to single-pointing 0-80 screws, etc.. So, as a breather, I knock off a few items on the production project list. This approach works well for me since, with no model project waiting on the item, I'm motivated to spend the time to design and build the production item properly so it becomes a truly flexible addition to my tool arsenal.
After a few years of this regimen, I find now that most of the kit I need to make something is already in the arsenal and there is much less diversion while making an actual engine or model. Put another way, the number of "work arounds" diminishes and the craftsmanship level on the models increases. Both effects bolster the motivation level.
