Hi everybody !
A project that I aim to : Ford-model A 1930
![1930-ford-model-a (5).jpg 1930-ford-model-a (5).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/75/75246-1930-ford-model-a-5-.jpg)
![164486.jpg 164486.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/75/75249-164486.jpg)
![164484.jpg 164484.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/75/75248-164484.jpg)
That's for sure , Thanks !if you start and make a mistake dont give up there is most always a way around it may take longer but just carry on
That is a wonderful thing ! Thanks for help.i will find some more photos of the internals
Thanks for posting a simple motivating message... just when I was considering scrapping a boiler that leaks...hi there
no i purchased the castings with no drawings and none availiable i sat down with the original spec sheet for the full size engine and worked to fit with what i had
i made one crank and found the stroke just a little too long so started again this time success
bore 17mm stroke 16mm
hi there
Hi Minh Thanh!Hi everybody !
A project that I aim to : Ford-model A 1930View attachment 121424View attachment 121427View attachment 121426
If possible, I only need the size of the engine block, which will help me a lot in my designthese are all i have at the moment but if you want i can post the specs that i roughly adhered to when making the internals i would have to double check some of the dimentions as some didnt scale exactly
Hi Minh Thanh!
Are you going to build a scaled model of the complete car, including engine and transmission?
TKS,
Edi
hi there
This engine looks like the previous Model "T" engine and transmission. Production of the T ended in 1927. From seeing other photos, there is a coil box, and that was not on a Model A, as a distributor design was introduced, where the high voltage was from a single coil, verses the Model T which had a dedicated vibrating coil for each spark plug. The transmission in this diagram appears to be the planetary design, and not the 3 speed with a single clutch.Hi Everybody !
Just a little View attachment 121973
