What is the function of C1? Speaking of multi-spark pulsers, this link has some info: http://www.sci-experiments.com/HighVoltagePulser/
RWO
Don't get me started on that one!It's a myth that the condensor across the points does nothing more than protect the points from arcing.
It does do that with points, but it also beefs up the spark by creating a resonant circuit with the coil. The same thing holds true when using a transistor as a switch.
You will get a spark without a condensor (or C1), but for all intents and purposes, the coil's output voltage duration will be shortened. This is of course a practical explanation - keeping it in English!
John:
Do you have a quick calculation for a proper capacitor value?
Sage
John:
Sage
It's very informative for me thanks for share.
Thanks. I've been trying to beg or borrow a high voltage scope probe to make life easier during experimentation so I can use a regular oscilloscope.
I have an old CRT type ignition analyzer, but it's big, bulky and has no waveform storage capability so documentation would be nearly impossible.
Well, John, let's think about your assertion. Let's look at cars per your suggestion. How about GM cars? The GM HEI ignition is certainly well known and many millions were made over many years. As to performance, the late versions were good to 8000 RPM on a V8. Did it use a C1? No. Of course, the HEI is now obsolete as the car makers have all gone to coil-on- plug or coil-near-plug. Some of the systems put the transistor switch inside the individual coil can. Do the coils have a parallel cap? None that I have seen. My old 86 Nissan put the transistor switch on the coil's mounting bracket. There was no C1.
RWO
