A BEAM ENGINE
hi
A slight change of plan with the safety valve cover, I decided there is no need to silver solder the two parts together they fit ok as they are.
I have started to make a new steam valve to replace the tapered one that leaks a little. Here's a drawing. As is my usual way when I make a one off part I make it first then measure afterwards and do a drawing. The sizes on the drawing are the actual sizes the parts ended up as.
here's the parts so far laid out on the drawing.
Partially assembled.
It needs to be silver soldered together yet and some final trimming. The needle has to have some of the square end turned round and threaded to take a brass nut.
Rich
As always Rich, true beauty and craftsmanship to behold. Thm: So **** and span, nicely sorted .... well, you get the idea, BRAVO!!
BC1
Jim
Hi
Thanks Jim
I finished the new valve today. Silver soldered the parts together and polished up. One cock up though. :( :( :( I tried to turn a short section of the needle down to a 1/16 to thread for a nut to hold the hand wheel on but advanced the cross slide a little too far and snapped the end of the needle off. fortunately it left a little of the square section, enough to push the hand wheel onto and then secure with super glue. I'll make a new one when time permits.
here's the completed valve.
And fitted to the boiler.
Next I made up a couple of pipes.
This is the steam feed pipe, it's 1/8.
It needs to be shaped better and lagged yet.
This is the steam exhaust pipe, it's 3/16.
Rich
Hi
woohoo1 woohoo1 woohoo1 woohoo1 woohoo1
It runs on steam. Have a look
[ame]http://www.youtube.com/watch?v=m12bdcT-Yn0[/ame]
There is nothing quite like the sound of an engine running on steam. The smell, the drips of water and oil
;D ;D ;D ;D ;D ;D ;D
Rich
th_wav Well done Rich ;D - runs like a charm !
Congratulations!
Kind regards, Arnold
Great runner rich, way to go! and way to recycle too ;) a job well done
Stew
Rich
Sounds even better than it looks, and it looks great :bow: :bow:
Great job.
Cheers, Joe
That was great.
When you let out the steam and started the engine...that was awesome.
I love the sound.
Congratulations.
(But I wish it hadn't been night out. I do enjoy seeing out your windows. ;D )
Thank you so much for the time you have taken to produce the photos and the videos it is clear to me that you enjoy sharing as much as the sense of achievement which come from your excellent work a big thank you.
Mark
Amazing! Really good Rich, a family heirloom that is. So much nicer seeing engines running on steam, you must have asbestos fingers though! ;)
Hi
Thanks Carl, it does sound nice doesn't it. Mark,thanks, a big part of this hobby is the sharing and I do enjoy it. Thank you Nick, funnily enough its not that hot.
Rich
Hi
I took the steam feed pipe off and lagged it today. A drop of super glue on one end holds the string in place then wind it round tight to the other end and secure with another drop of super glue. To get a nice white look I paint the string with typists correction fluid.
I have decided to call an end to this model now. My intention was to build a small boiler feed pump and a dynamo to power a couple of lamps but I'm going to leave that for a future project. I have a couple of workshop tooling projects I want to get on with and then make a start on my next model.
My thanks to all that have posted comments, they are most welcome. :bow: :bow: :bow:
Rich
th_confused0052 WOW th_confused0052
I am not sure how i missed this post Rich...
But it was an amazing read!!!!
Excellent workmanship!!
Takes a great mind to build something like that!! :bow:
Andrew
I too missed this WIP. A super job on the beam engine. I did not see a reference to "steampunk" but surely this would qualify. I say that with the highest of complements on a job well done.
Phil
Hi
Thanks Andrew and Phil.
The engine is still sitting on my bench along side the small steam plant at the moment. I have been busy with domestic duties for the last couple of months but have nearly finished now. It will be a shame to pack them away under the bench so I have room to start my next model.
Rich
