- Mar 9, 2010
- 597
- 704
Just finished a new 6-cylinder radial steam engine - my own design, with a 1/2" bore and 1/2" stroke. I've built a number of kit engines (Stuart, PM Research, etc), and this is my first foray into building from scratch. I've always been intrigued by radials, and thought it would make a great project. Turned out well, even with the many many disassembles/reassembles to get it right!
The size was mainly determined by the size of the aluminum block I had for the crankcase, and the size of the bar stock I had for the cylinders. It uses slide rod spool valves bored through the same block as the cylinders - this kept the design simpler. A goal of it was to be able to make the whole thing without any castings (except for the flywheel, which I already had a spare of).
Got it running this morning, hooked up to an air compressor. It runs quick at 40 pounds, and slows down to just ticking over at 5-8 pounds.
I've done a photo build log, with plans, and am uploading that to the downloads area. Here is a photo of it, and a link to a video of it running. Really fun project!
Video:
[ame]http://www.youtube.com/watch?v=oHfb2sPbHPs[/ame]
Video:
