Bob,
Good point about the card thickness. I found my playing cards to be about 11 thou thick. It's a good idea to have a variety of gaskets so that you can experiment with different port timings. I also made 3 conrods that were different with about a 10 thou range in distance between crank pin and wrist pin holes. This provided an easy way to compensate for some accumulated error.
You may want to rig a timing jig with a protractor just to make sure your port timings are as desired. Just bolt the protractor in place of a prop and rig up a block scriber so that you can indicate the markings off the side of the protractor. Then, flash a penlight into your cylinder while rotating the protractor (and the crankshaft) and note when the piston covers and uncovers the intake, transfer and exhaust ports. This will give you an idea of how close you are.
Best wishes!
George
