I decided over Christmas that I would make a replacement clip for my coffee machine and found a piece of 316L sheet that would do. The clip is like a washer but has three tabs on the inside and it slips on, sort of bayonet fashion, to secure the filter in the handle of the espresso machine.
Back to the plan.
I decided to chop off a square from the 2mm sheet as a starting point. I thought I'd drill an 8mm hole and hold it by a nut and bolt which would then go in the collet chuck. The pilot drill went through, with a lot of screeching but the 8mm drill now looks like a counterbore cutter. It definitely didn't want to cut any longer.
Never mind, I'll use an end mill in the mill. Now I need a new 8mm end mill as well.
Is there a way to get rid of work hardening in this devilish stuff?
BTW the 304 worked better, but had it's moments too.
Back to the plan.
