Nice work geek boy
I am actually using mine now to make money, I replaced all control cables after a week as they were terrible. Mine was also packed exactly the same as yours. after 6 months of daily use, mine will hold0 .02 mm every time. thats 2 microns. I use it to make parts for model aircraft and some special parts for sale to private clubs and its used every day. Buy the cam bam licence, its well worth it although you will have found that if you don't shut it down on the computer, then one use can last you days and you have 40 uses. I also bought the mach 3 software and the 2 together are working a treat. I have been using double sided carpet tape since I started. The smooth stuff, not the rough stuff. Your pocket will be fine for location. I use a 100mm square pocket with the bottom right corner set at x0z0. All you do then is have a series of templates that you fit into the corner and hey presto.
The machine is now 100% reliable, the steppers are fine and the blue box has given great service. I think the fan is now failing but as the box's only moving part, thats an easy fix.
Al
Al
