lennardhme
Good going,
I have the plans for this engine & your thread will be a great help.
thanks.
thanks.
Terryzilla, seeing that you intend to build this engine, I assume that you have the drawings. The area's that I found problems with are the legs, they should have a hole in the centre to suit a 4mm screw, not 3mm as shown, also if you want to have the legs protrude on the outside as shown on the assembly, the outside diameters should be 30 and 36mm, although I used 34 for the largest. The other problems were with the cylinder, the slot that is the air intake is shown 12mm to the centre of the slot in the side view, this should be 11.5mm. Next one, in the end view of the cylinder, the 2 holes that the valve pivot block screws to are shown as 4mm from the bottom, this should be 3.5mm.
Jyman, I think that you may be on to something there, the cylinder certainly gets hot and could prevent the air from cooling and creating a vacuum. I will have to try your ice idea, I'm using methylated spirits in the burner, maybe there is something else that I could use that burns cooler.
Gus, the weather has started to cool a bit now with the days generally mid to low 20's, great autumn weather. I'm off with a couple of mates next week for a day of fly fishing. We want to explore a river about 2.5hrs away from home, reports haven't been promising but we will give it a good go. It will be great to get away for the day anyway, we always have a good time even if the fish are scarce.
Paul.
What a frustrating engine I have been fiddling around with the engine making minor mods to it, I even managed to buy some isopropyl alcohol to use in the burner, the only problem there was that the only source that I could find was in a 125ml spray bottle, the price equated out to $60 per litre, as there was no improvement, I will stick to methylated spirits.
The engine definitely wants to run when the flame is there, but only for a dozen revolutions before I have to spin the flywheel again by hand. I think that I will just put it on the shelf for now and bring it out occasionally to see what I can do to get it to run. I need to get on to a new project that's more constructive.
Paul.
