Hi Eddie,
The tank design uses tubes with 6mm bores, hence the wick size needed. The one I got was a bit large, but will see if I can get it to fit.
I intend to run the burners with methylated spirits, I assume it will give me less smell. Thanks for the links, will chase them up if needed. I am getting much better every day now, so will be back machining once Christmas is over.
Walked into the garage the other day, and noticed a large puddle of water on the floor. The carpet that I stand on at my bench was saturated, and several cardboard boxes were sodden. Could not find where the water had come from, until it dawned on me that somehow the drain on my compressor must have let the condensation in the tank out. I haven't drained it for quite a while, and was using it quite regularly, just how it managed to leak is a bit of a mystery, but I will check it our shortly.
Paul.
