Your dog is stealing your show.
He always does.... and knows exactly how to accomplish it seamlessly.Your dog is stealing your show.
The fixture does more than the 45. Plus this way its straight across the part...not stepping the angle down across the part. The cuts were small to keep ing harmonic to a minimum... took forever.Why didn't you mount the casting on its feet to the mill table and then tilt the mill's head 45°? I know it would take more math to work out the cut positions, but it would have saved making the fixture.
What do you use for fuel...id prefer NOT using propane due to the stink in these engines. Was hoping a lunkenheimer carb would work with a liquid fuel....If they were easy to build, any fool could do it. Mine is#378 purchased Feb 2022,took about 6 months to build. I made a plywood holder similar to the fixture made by pamw to hold base while machining for crankshaft. Keep at it! A very satisfying engine when finished and running. Mine never fails to start and runs great. A crowd pleaser , one of the best engines I've got.(17) There is a short build log of mine in Engines from Castings Oct 2022.
Colin
Been running colman white gas...smells like a zippo lighter....I used propane ,I find it does not smell, where gas engines do.
Colin
He enjoys the spot lightLooks like you are on a roll.
I see the ever-present little helper under the table.
