The crankshaft is identical to the crankshaft of a straight 6-cylinder
The project is taking shape, the main components are designed
snip
Hmmmmmmmm - - - what program are you doing your modelling in please?
Thanks - - - - I'll pass on that option - - - - for a number of reasons.Fusion, but I think all 3D programs can do these simple designs..
Have a look at a Linux operating system (I use Mint), and Blender for the modelling. Both free.Thanks - - - - I'll pass on that option - - - - for a number of reasons.
I 'gave up' (passed) on Microsoft's continuing and ongoing 'security opportunities'.
Autodesk has a history of pulling out the rug from under its low cost (and especially free) offerings.
AIUI windows is now even setup so that Win11 really doesn't work on even an air gapped machine which is the only way that I would run such.
Hmmmmmmmmm - - - if you call what you have presented 'simple designs' - - - - dunno what you might call complicated - - - grin.
You will have at least 40 if not 75 different pieces you'll need to model - - - hmmmmmm likely fall into my definition of 'not simple'.
Continuing to follow your intriguing thread.
Thank you!Have a look at a Linux operating system (I use Mint), and Blender for the modelling. Both free.
Remember the spark will occur at some advance, before the piston is at the top of its travel.
If the cylinder head is flat, the piston shape will create a reverse squish band.
I can't guess what effect that might have on the flame front, but if it allows it down a lot, you will just need to use more advance on the ignition.
I am guessing you are not looking for maximum performance from this engine?
As I worked with piston and combustion chamber designers on a couple of engines: "modern thinking" - as of the late 1980s~90s. was to simply flatten the piston and head as much as possible. On CAD: Draw a sphere at BOTTOM dead centre and it should touch the cylinder walls, head and piston with very little overlap. That minimises heat loss to the metal when a spherical flame develops as the piston travels down the bore. (This was developed in laboratories with single cylinder "see through" engines, lazers, etc.).Cylinder and piston: in the original engine the spark plug is directly on the cylinder, the piston is concave and the petrol is ignited correctly. In my engine ,to have a correct compression ratio , I had to make a dome on the piston to leave the spark plug uncovered.
i think it is not a good solution but i have no alternative. I do not know if the ignition of the petrol will take place uniformly and immediately.
Your every suggestion will be appreciated
I really appreciated your suggestion, even a friend of mine who builds engine models suggested a similar thing to me. “The flame triggered by the spark plug must reach the center of the piston.“As I worked with piston and combustion chamber designers on a couple of engines: "modern thinking" - as of the late 1980s~90s. was to simply flatten the piston and head as much as possible. On CAD: Draw a sphere at BOTTOM dead centre and it should touch the cylinder walls, head and piston with very little overlap. That minimises heat loss to the metal when a spherical flame develops as the piston travels down the bore. (This was developed in laboratories with single cylinder "see through" engines, lazers, etc.).
On Model (seriously small engines, sub-50cc per cylinder) the heat losses to adjacent metal are much worse than your small car engine, and low compression makes things worse.
I would therefore, remembering that the piston does not rotate, simply mill a small pocket for the spark-plug, and a curved bottom groove from there to the middle of the piston, with maybe a SLIGHT dishing of the piston crown). The flame generated by the spark ignition will then progress up the channel to the centre of the piston to meet the remainder of the charge and burn that as the piston travels down the bore.
I have done a quick sketch... - Hope it makes sense?
Ask more questions if you wish...
K2.
sorry for my mistake 18 pistons + 2 extras = 20 not 2626 pistons? You making 8 extras, or did I miss something?
