Colin--since both cams are attached to the same shaft, any change I made influenced both cams. What I actually did was retard the cam-shaft, which retarded the two cams attached to it.---Brian
I just set the crankshaft in the correct position rotationally, removed the gear cover, loosened off the set screws on the crankshaft gear, and turned the crankshaft gear by hand until I seen that the exhaust was starting to open, then locked up and reassembled everything.---Brian
I thought intake followed exhaust.
that is $10 American for each of the rings and $20 American for shipping.
