I have been busy on the engine working on the water pump and associated piping. I ended up making a 6x80 tap to make a couple of unions for the piping.
The small tubes were bent with some home made tube benders the tube was annealed and filled with some styrene rod bent then re heated to burn out the styrene, this worked very well.
next I tackled the spark plugs I cut a couple of 1/8th square strips of a corian cutting board.
turned them down to .078" and drilled a .028" hole for the music wire electrode.
The body was made from a piece of Allen head key that was annealed it was 9/64 across the flats
I tested the plugs with a pietz cristal and they seemed to spark OK.
After filing and fitting the water cavity cover the circular plates have been turned from 3/8 bar stock.
some 00x90 round head screws were machined up from some 00x90 hex head bolts , the stock 00x90 round head screws were too large in diameter.
and to bring it all up to date the excentric cam parts are now being made from some stainless.
That is all for now
Mike
