The block's front end was machined similarly to its rear end leaving .010" excess deck material for indicating and later finishing. I'm not sure why I drilled that pair of 7" deep 1/4" diameter coolant holes through the front of the first (scrapped) block. They only needed to be deep enough to penetrate the cooling jackets of the two front cylinders. Since the jackets overlap between cylinders, coolant will flow through the block without those deep holes.
The block's front-end features were roughed-in using 3/8"and 1/4" end mills before being finished with an extended reach 1/4" ball cutter. Most of the front-end's modeling time was spent adapting the full-size engine's filleting to this particular cutter. The organic cavities between the camshaft and distributor bores ended up with fillets stacked upon fillets, and the whole thing was a house of cards ready to fall with any changes to the design. It was this area that drove my decision to correct the timing sprocket error by moving the crankshaft up rather than the camshaft down. Since the fuel pump and dipstick will be later add-ons, the front-end machining is essentially completed.
The original workpiece was carefully machined so its surfaces could be used to indicate the block within its various machining setups. As the workpiece is machined away, work-holding and indicating become more difficult. To fix this, a fixture plate was machined next. It bolts onto the bottom of the block through the oil pan holes and is dowelled to it.
An angle table will be used for the 45 degree and 225 degree setups. The fixture plate will be required in the two 45 degree deck milling operations. The block will have to be flipped over for the two side milling operations which require the 225 degree setups. To keep the setups rigid, the block will be clamped to the angle table with a bar run through the crank bearing webs. On the surface plate this bar indicated true to within a thousandth on all block axes.
The Enco angle table I own is rigid enough, but precision is sorely lacking. Its most frustrating issue is the ground slots which aren't parallel with the table's rotational axis. This error which is nearly .050" at 45 degrees varies with the tilt angle, and changes when clamped down to the mill table. I typically re-machine a portion of the table every time I use it, but this only makes things worse for the next setup.
For this build, the table's 45 degree tilt was indicated on a surface plate using the deck reference surfaces machined on the block's front and rear ends. Custom tee-nuts were machined to allow the workpiece to be shimmed into alignment. Of course, when moved to the mill, all this will have to be re-tweaked.
I'm still working up a machining sequence to make best use of the workpiece during the remaining operations. - Terry
