VW Beetle engine 1/5 scale
Not to take you too far off into the weeds but how much pressure does it take to push the hot rubber into the mould and what kind of connector are you using for the top of the plug? Bob
I cut the rubber to fit into the mould. Not a precize cut at all, just making sure there is more rubber than actually needed. The add temperature and the rubber become very soft. There is not a high pressure needed. You could have done this in a vice if you had hot plate on each side of the mould. I guess some 100kilo for 100cm2 (I dont have a gauge on the vulcanize press.).
I had to use a 1kohm (1/4w) resistor in the rubber boot, if not my microcontroller chrash. I simply make some loops at the end of this resistor to touch the sparkplug. There is enough friction on the rubber, so it wont fall off.
It's going slowly, but I'm not in a hurry.
No customer is waiting for me!😅 Last week I've been milling out holes in the crank case for the cylinders, and also turned the last cylinder! Then making studs x 16 (not cut to lenght). It's from Ø2.5mm 316, so pretty hard. The M2.5 die I got is of poor quality, so the threads does'nt looks very good. I have to purchase a better one on Monday. Ghuring or Swiss-tech, or..."Baer"(never heard about Baer, but expensive, is that good?
    4.8 MB
Nice work.
I'm not sure about 316 for the head studs. It's not easy to thread nicely, especially at small diameter with a die. Stainless threads have a tendency to gall in use.
I would have used EN16T. Higher strength and stiffness and easier to cut a nice thread.
Looks Great - NICE job!
head studs on 1300, 1500, 1600 cc VW air-cooled engine with single-port heads, were 240mm long for the lower row, and 202 - 204mm long for the upper row. M10 x 1.5 threads. In 73, VW switched to M8 x 1.25 threaded studs made of a better grade alloy, that acted more like a "spring". Performed significantly better.
Rocker ratio was 1.1 : 1
Have been thinking about how to make the corrugated pushrod tubes ... have you considered hydro forming thin tubing? ( maybe from 1100 or 3003 aluminum, may have to machine your own tubes from solid bar stock to get size & wall thickness to suit 1/5th scale) Machine a split die from alum or steel with rounded grooved to form the corrugations set back say, 5mm, from the ends. Plug the ends of the tube, with one plug fitted for a common pressure** washer hose connector. you can always cut off excess from ends, if threaded plugs are used.
** like the unit used in this video
Alternatively, a split block die just long enough for one end's corrugations could be clamped/bolted tightly around a one one of a tube held in a lathe chuck, make a tool with an appropriately sized/shaped smooth steel "roller" wheel, to fit inside the tube, and while spinning the tube/die assembly, "align the wheel with a groove to roll-form the corrugations. Dead soft annealed copper tube may work too, although you may have to roll in stages and anneal with a propane torch in between - to prevent work hardening. leave straid tube enough on the ends to fit o-ring seals. The VW are made of welded seam steel tube with approx 0.45 mm thickness.
One last thought: make a die for small rubber bellows to slip over a length of straight tube, with the tube being a couple of corugations shy in length.. make one end of the bellows a bit thicker, to act as a seal. The assembly will look similar to the original tube, flex into position and seal.
I think hydroforming such a small part will be difficult, but you gave me an idea! If I use casted polyurethane ends that slides into the steel tube with spring load, then it will seal and looks close to the original. (The tube is Ø5mm at at the centerpart, with Ø6 at the ends that hold the spring in position)
I think that's a good way of doing it. I had similar issue on my radial where the tube mated the rocker box at a 3D inclined angle. I bonded a collar onto the tube & then had an O-ring under light compression, which both sealed & conformed to any slight surface discrepancy. Some kind of elastomeric material is desirable IMO to help snub under vibration & allow for change under temperature. Just pay attention to the pushrod OD vs tube ID & confirm it doesnt rub. because typically is a 3D motion. not just in the rocker arm plane
    195.3 KB
    211.4 KB
I have now started working at the engine tops. I've decided to mill it out from a 7075 alu block instead of casting. I made a aluminium cast for one top, but there is so much left to machine, and so fragile alu with the 0.5mm ribs, so I think its easier to make it from a non-porious solid block.
But, one question circulate in my brain: Why does all the model engine I've seen seems to have under-dimentional valves? In a full size engine there is always an eager to get the valves as big as possible!
When there is room for it, is it any reason for that the valves seems unnecessary "small" in a model cmbustion engine? Do I miss something? I already seen that the carburattor must be small (- for my engine about Ø4-4.5mm + venturi), and I can understand that. Because it need to be small to get enough speed/airflow to atomize. (Not a complete design on this picture, -missing sparkplug and bigger combustion chamber.)
    189.1 KB
NICE WORK ! are you going to leave rocker arm assembly mounting bosses - also bosses on each end of the head for the valve cover bale? just curious... lots of work ahead (no pun intended :)
pics of 1.5l/1.6L single port VW heads I recently rebuilt, and a 1.6L dual port, for folks who may not be as familiar with them:
    673.8 KB
    305.4 KB
    43.9 KB
I 'll make it simple as possible! the rocker arm will be something like this:
Hammer and rocker will be cast in bronze..
Slowly getting forward. Been sick for a while, but better now. Working on the tops. Ø7 and Ø8 for the valve "housing" been milled. Also a step down 6mm for the top housing. Not that easy with no CNC, but being careful it will work.
    134.4 KB
    147.8 KB
Nice work!
I have done quite a lot of complex milling manually. I spend considerably more time making fixtures and setting up than actually making parts. On several occasions, I have had to show photos of my process to convince people that I don't have CNC machines.
I take the view that this is a hobby and the longer it takes me to machine a few quids worth of material, the more effective the hobby. By comparison with other hobbies, e.g. golf club membership or tickets to football games, this is a very low cost way to spend time - and infinitely more satisfying!
Arild,
Some thoughts. I have been a engine modeler for many, many years. I have probably come across almost every conceivable machining situation in machining parts for engines. When scratch building in smaller scales a lot of compensations have to be made to support a running engine in the end. Trying to model full sized parts into reduced sizes isn't always feasible. Things like wall thicknesses, fastener sizes, and peripheral parts like distributors and carburetors.
Yes as a machinist I can make all the parts at a given scale to make a museum replica piece but will the engine run, no. You encountered issues with cutting fins on the cylinders and worked through it but maybe by reducing the number of fins and thereby making the recesses a little wider it would have simplified. the task.
I had always wanted to build a miniature (1/3 scale) Ford flathead V-8 engine. Try as I might there was no way I could design or make a replica of the cylinder block. (Exhaust ports through the water jackets) I therefore designed everything from a Ford flathead but with the exception of the exhaust. If the builder wants a running engine then the goal should be to replicate as much as possible so that anyone who looks at the finished engine will say, "that looks like a VW engine." They aren't going to count fins or look for a bump on the crankcase that's missing they are just going to recognize the overall presentation.
As a scratch builder I know all the things you are going through and applaud your work.
As far as carburetion here's my thoughts. Start with a single carb. No matter how much work it takes to make the manifold. Trying to synchronize 2 small carbs is very troublesome. I went through that with my flathead engine. Once you get the engine running and the bugs worked out, carburetion, ignition, etc. you can always go back and make a second carb and manifold. As far as carb sizing goes. My 302 Ford V-8 replica has a 1.00 bore and .900 stroke. (25.4 x 22.86) The carburetor venturi is .215 diameter (5.5mm) The engine will rev to 7,800 rpm. Would it rev higher with a larger carb, maybe but I'm happy with it. With carbs always start smaller. An engine will run with a small carb much better than a large one.
Just some picture of progress in my build.. The orange parts are 3D printed parts that will help me with alignments.
I have made the cylinders black (heat and oil), so they looks nice!😁.
I've also milled the combustion dome with my specially made HSS 6x6mm hardsoldered on a Ø15mm axle and then grinded to shape. -This is not scale, but who cares? The compression is calculated to be 1:10 and that should be more than enough.
Next up is to drill the intake ("sparkplug drilling" picture) and sparkplug drill. That will be the most nerve-wracking so far I guess!
I have wrecked 3 tops so far, but not that long in the process. I use those part to practice on now, so hopefully this two will be ok.
Bore is 18.6mm, stroke 14mm. Total about 15.2ccm (or 1900ccm in full scale..)
The ignition system will be fully electronic - with a pick up magnet on the flywheel, so no distributor. -That would be too small for me!
    100.8 KB
    130.7 KB
    99.1 KB
    144.1 KB
    125 KB
    115.2 KB
    146.9 KB
Could you explain your ignition system in a little more detail?
I am curious.
Ray
Hello Ray! I use a microcontroller from Microchip to control a LCD and send on/off to a "taser" module (20kv module bought on Ebay). The microcontroller receive signal from one magnet mountet on the flywheel and stationary hall-switch. Among with a software program it will control the sparks. In the software I can set the advance timing as I want.
It uses "wasted spark" system, so one coil control the sparks on two spark plugs.
(I am an electronic and mechanic engineer)
  • Ignition system.mp4
    5.8 MB
  • 20240113_222113.mp4
    22.9 MB
That's really cool. Now do you mean you plan on harvesting the taser coil & wire onto a more conventional looking spark plug body, or these white housings somehow reside over your combustion chamber with the spark wires protruding inside? Have you tried igniting gas vapor in a test cylinder yet or still at the electronics stage?
More like this.. (now the white turned into red)
    309.5 KB
Back to your push rod tubes, To save some headache, you really on[y need to have a spring on one end of the tube. I assume you are installing valve seats. It looks like you machined a domed chamber. The VW uses a flat chamber top, your seats are going to be machined mighty deep in the head and you are going to have a lot of unshrouding around the valves. It looks like your valves are not centered enought in the chamber.
I feel very happy! I Made pilot holes for what I fear most - the intake. "double angle" and very small. I hit the target - not perfect according to drawing, but good enough. Ø4mm holes. The little "❤️" is the intake to both cylinders. (it will be milled round later) This will be a "single port" beetle engine 1900ccm
    116.9 KB
    157.3 KB
Nice. So in that picture
- is it driving regular spark plugs like commercial RCEXL 1/4-32 type (or home made equivalent)
- are the taser modules divided one per 2 plugs because of the duty cycle = time required to charge = 'dwell? (sheesh, you can tell I am NOT an electrical person haha. Do those specs translate into some kind of max RPM per cylinder?
- does your Arduino sense RPM & then you have some kind of programmable advance/retard curve mapped in the background?
- what kind of battery / power requirement for a typical
Sorry for all the ignition related questions. I'm slowly getting my head around spark ignition from other model engineer contributors & this seems quite unique. If it wasn't for you smart electrical guys, I'd be using glow plugs forever!
