New chuck.
SmithDoor
Staff member
Global Moderator
Clovis Ca
Just received my new 4 jaw chuck for my new 3" rotary table.
The new chuck is 48mm can hold just little over 2"
I have larger 4 jaw chuck
I what a small one for small parts.
Here other 4jaw 5"
I also have 6" 4 jaw fof large rotary table.
Are those die-cast jaws?
Yes die cast.
The cost for steel chuck is about 10x.
It is very hard but i would use for any type turning.
It for light work only.
Heavy work I goto my 8" Table with a 6" steel chuck.
My little 3" rotarytable is being setup for use in a vise.
Makes doing fast projects easy
Herd chuck Backplate I planing making on warmer days.
Note ¼ NC Tape for hold down
UPDATE
Just starting to machine the chuck mount yesterday see photo below . Today it is to cold ☃ ❅ 🌦 now .
{{ Mockup mount , chuck & rotary table. }}
Here mockup of chuck on rotary table.
Note 3" barstock for chuck adapter. The table is only 3" diameter
The chuck 1.89" [48 mm] for small work
FYI I 5" for larger work too
{{ FYI why use a 4 jaw on Rotary Table}}
Most time I would tap and a little clamping pressure.
A 4jaw I can adjust just like a lathe in just few minutes be machining in the rotary table.
The mount instead of a through I have a threaded center for clamping down tall parts.
PS
If ask modt how clamp apart you great answers. Most cases it was a 3 jaw chuck , use Morse taper w/drill chuck or use center hole a and pilot on part.
Dave these are my small chucks off my unimat db200
4jaw is 2-1/3” 3jaw is 2-1/8” both M1-12 thread
I made the straight & MT#2 arbors.
#2 is for my 6” RT
MT #3 & straight arbor is for my old SB9
#3 MT arbor was a drill chuck arbor I cut off & threaded.
#2 & #3 arbors are threaded for draw bar or pull bolt.
The Norton chuck 3jaw is 5”
    1.9 MB
    7.3 MB
    6.8 MB
#2 is for my 6” RT
Looks great
The small 3" rotary tables do not have Morse taper.
My large 8" table has #3 Morse.
I wish if all rotary had a larger hole for long bars.
Like spline shafts on engines.
FYI The way I do long shafts need is make a little longer with stub for chucking in Dividing head. After spline are finished cut sub off.
On repair a spline shft just stub on and machine the stub the mill spline.
⫷⸻❋ UPDATE ❋⸻⫸​
Here adapter plate being machined. Note the tap hole in the center ¼" x 20 fof long parts like a drawbar
Red Dykem ready for lay and drilling
I wish I had this rotary table and chuck in 1970’s when I was into model aircraft engines.
⫷⸻❋Finish 4 chuck to table ❋⸻⫸​
Here is the Finish photos
The last minute upgrade the chuck had only 2 #2 size mm to hold so graded to a large bolt
Here backside
Note AHCS IN center of large bolt
The chuck came with the mount to drill chucks.
Finish with larger bolt installed
Nice resuts, Dave; should come in handy.
Thank you
I have bigger and unless I have use a rotary milling I just hand layout .
With my old Mori Seki I had 6" 4 jaw chuck on a stub when need a small 4 jaw work.
I wish did this in 1970’s on larger mills maybe a 6" rotary table with 4 jaw chuck and set so Icold use vise to hold the rotary table.
Looks a good job and will be useful.
Yes it get lot use than large sits on shelf.
I have setup for holding 3" rotary table with chuck in vise or in the lathe.
I have wonder how many have rotary table. Most time I either took flat Plate drill and bolt to table or use 4 jaw with clamp to the table. This is a upgrade
Most time I would bolt the new part down and do all the rotary milling first .
In some case I would cut part to size after the rotary milling was done.
If had lineup on table I have different size hammers for tapping. Or a 4jaw off the sb9. I did purchase a 4 jaw for my large table and never setup just clamp the chuck down.
I am only doing small fun work now
