Finger Engine - my first build
Mandan, ND
The first plan was to make a wobbler, but then I saw the plans for a finger engine and figured it would be a better first project. The finger tab looks much easier to make than a cylinder and piston.
It is done enough to assemble on a temporary base to work out any fine tuning. I have a piece of hardwood picked out for the base and am finishing it as I work on the last little details of the engine. It was fun and educational and I got to use the new DRO setup on the mill. I must say that the 1/2 function and the bolt circle function are my two favorite "tricks".
"Tricks are for Kids". Well, I'm still a kid at heart, so there's that....
Looking good! Did you follow one of the plans out there (which one?) or is it your own design?
Craig
It was from plans by Kaje that I found on this site, which is a modified version of the NAMES plans.
The plans are nice and clean and easy to follow. The only issue I had is what I think is an error in the notes for the finger pad. It calls for a depression 0.150" deep in .25" stock, but then the holes from the bottom are 0.185" deep which resulted in a breakthrough. I remade the part from thicker stock but after assembly I think the depression is too deep to be comfortable. Perhaps it should have been 0.050". The current plan is to take it off and mill the top edge down until I like the feel of it a little better.
The only real change I made was how the crank connects to the shaft. I didn't have the set screw size called for, and I didn't have a tap for the set screws in my stockpile. Grrr! BUT I had a bag of 3/0 taper pins and a reamer for them, so changed to a taper pin. My pins were short enough that reaming the depth carefully I was able to "bury" the pin totally inside the crank out of view. It makes a secure connection but comes apart easily.
There are some small errors (mine) that you could find with a calipers or a careful eye, but for the most part it looks proper.
