Laser Scribed HRS
Texas
Im building Elmer's 46 Comber. In the process of laying out the cam per Elmer's instructions I found out how old Ive become as essential tremors and degraded eyesight made hand lay out of the cam ID extremely frustrating, especially when it came to dividing the 180 degree, .250"R arc into 12 equal arc segments. Thinking I could draw this all day long in CAD I began to wonder if my little 10W laser would mark the steel. I put the HRS plate coated with blue layout dye on the laser and in a corner that would eventually become drop I ran the laser to scribe a 2mm circle. To my amazement the mark was crisp and clear against the layout dye. As glass is laser etched by first spraying the glass with black paint I assumed the layout dye was responsible for the effect on steel as well. Flipping the plate over I ground off the mill scale (which I hadn't done on the first side) and used layout dye. The marking now left by the laser was faint, barely visible. As it turned out the laser was etching the mill scale. I cut another plate, leaving the mill scale and using layout dye (for contrast) I got this result. Im moving forward again. FWIW.
    898.2 KB
What type of laser ist that? I had a look at 20-30 W lasers with 1065 nm, but they are quite expensive and I must admit I find them scary.
( no enclosure whatsoever)
Greetings Timo
Greetings Timo
Hi Timo
The laser is a Creality Falcon 10W. My wife got it for me as a gift a couple years ago when I was scratch building r/c airplanes. Ive tested it on metals periodically over that time with the intent of only marking parts... with disappointing results. This is the first time Ive seen useable results, but remember this only appears to affect the mill scale on HRS.
Theres nothing to be afraid of. Cardboard will block the light. It is a burning process so dont leave it unattended.
Pete
When engraving metal I fear even a partial diffuse reflection might severely damage eye sight. I once helped installing a 3mW distance sensor, it had to be min. 3m above floor level, so that no one could look into it by accident. A non reflective target had to be mounted on the opposite side, to avoid unwanted random reflections. It was mandatory to install warning signs on the entrance of the work area. The laser was 1/3000 the power of yours. :)
At least yours has a basic plasic shade around the beam.
Some galvo lasers I saw have no protection whatsoever, at least the safety glases will be "a must".
Greetings Timo
More expensive fiber lasers that can engrave metal and that are fully enclosed and safety interlocked are available. Thunder Laser's Aurora series for example, but there are others. You could also fabricate your own enclosure from acrylic panels or provide safety glasses for anyone in the laser room. The latter is not likely to work for pets or small children though.
Another option for marking metal with a laser is one of the spray or brush-on laser marking solutions. Here is the one I have been using: https://www.amazon.com/gp/product/B09L4GDCN9/ - this is a significantly less expensive version of the "original" in this category: https://www.amazon.com/CerMark-Marking-Aerosol-Performance-Marketing/dp/B0CLF355ZB/.
No affiliation with either company, other than using the first of the above with complete satisfaction. Spray it on, let it dry, run the laser, rinse off - wherever the laser has been, the product bonds to the metal and seems pretty durable. Note that I have not tried this to make crisp layout marks, and probably is not the ideal product for that - it does require mechanical removal (sanding or scrubbing with a scotch-brite pad or similar).
