Hi
I am in complete agreement with Dan and Green Twin. Especially flux and cleaning.
Planning your job is important, you need to think about how much heat you need and where.
I use many different silver braze rods with different melt temps (Easy Flow and 56 two most used), also Harris Stay Brite #8 for a high temp silver bearing solder.
A recent project involved silver brazing was a crankcase for a 2 cylinder model. It is about 6” x 3” x 3” high. It had 19 separate brass pieces ranging in thickness from .1 to .25. Lots of sequence planning, I used three different melt temperature silver braze and one high temp silver solder. It took me several days with lots of trips to the pickle tank, fixtures and rest time. It was all done with a Sievert Propane system.
Here is what I use for various brazing / soldering jobs:
Mapp with a real old torch head - small items say no thicker than 3/16, depends on overall size, or larger with hot plate help
Oxy - Acy
Smith Little torch with low pressure Regulators - very small delicate items less than 3/32
Smith AW series (tips 000 to 7) – when I need lots of heat concentrated small or large
Sievert – on 20 Gal propane tank with Victor regulator to 40# (see Photo)
- When I need lots of heat on a large surface area, or round to flat (special tip)
I would guess that 60% or more of the items I silver braze for parts over the years used the Mapp torch. May take a minute or so more to heat up if using large materials but requires less setup ie getting out the tanks, the tips, etc.
