Hi All !
There are many ways to make dividing plate
Thanks for your comments and thanks for sharing !!
I just finished a dividing plate
A 40 and 35 hole plate
The 35 hole plate had 1 hole in the wrong position, I fixed it by pressing a small pin and re-drilling.
On the 40 and 35 plate there are 2 holes from which when changing the position between I can cut the 35 and 70 tooth gear
I will finish it and cut the gear and will inform the result
