Boiler end plates: First, determine the diameter which is the inside shell diameter minus x2 the thickness of the endplates, plus a hair more. I made a former out of hard oak floor remnant formed on lathe.
Cut out the endplates. I used .065 copper. Too thick for shears, and would not fit into my small plate shear. so had to use the lathe. This required a center bolt hole which will be used for the brass stay threaded lug. Cut copper out a bit bigger than the boiler diameter because you have to form the edge. If you do a nice job cutting it out, you will not have to trim anything after forming. Copper is a PITA to machine so go medium slow rpms with sharp cutting tool. I found that a few drops of tap magic worked fairly well.
Once the copper is cut out, heat it until light cherry red. I focused the heat on the edges that will be formed. Easy to form over hard oak a bit at a time. Took four heat cycles to get the piece perfect. Many little hammer dings which will fill with silver solder. SAnd and egt rid of any rough or sharp edges.
Then I gently pressed into boiler end after fluxing the boiler and the end plate. Silver soldered up well. Need to get near red hot for solder to flow. don't overdo the flux so less runs into boiler.
My torch is a small tip for fine work , but I have it hooked to a bottle of MAPP and a big O2 tank so it just works for the endplates. Nothing new if you have done this all before....
![IMG_6402 (400x300).jpg IMG_6402 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25739-IMG-6402-400x300-.jpg)
![IMG_6404 (400x300).jpg IMG_6404 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25740-IMG-6404-400x300-.jpg)
![IMG_6405 (400x300).jpg IMG_6405 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25741-IMG-6405-400x300-.jpg)
![IMG_6406 (400x300).jpg IMG_6406 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25742-IMG-6406-400x300-.jpg)
![IMG_6407 (400x300).jpg IMG_6407 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25743-IMG-6407-400x300-.jpg)
![IMG_6408 (400x300).jpg IMG_6408 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25744-IMG-6408-400x300-.jpg)
![IMG_6410 (400x300).jpg IMG_6410 (400x300).jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/25/25745-IMG-6410-400x300-.jpg)
