Bought this off ebay. The seller was super with fast shipping and great packing. The engine had many faults which probably happened ove time. Not to blame anyone, just describing them and the fixes.
Most of the original machining was excellent. Super smooth cylinder bores, perfectly fitting upper and lower covers, pistons and rods perfect. Base plate perfect. all cover holes and tapped block holes perfect.
Some issues included:
crank bent in more than one direction in more than one section.
Original parts stamped for position, but many in wrong positions
Mixing of BA and USA threads
Slide valves incorrect size and in wrong position
One broken piston ring (HP)
Missing many little parts
H2O pump scored internally
Pump holes drilled in wrong position
HP rod journal angled by 6 degrees from crank centerline, other two OK
Repairs included cutting out angled rod pin and drilling and brazing in a new 3/8th pin. Straightening crank which took about 3-4 hours and is now within 3 thou along the bearing length. 3-4 thou at crank end tip. Replacing all parts into appropriate positions and reaming the journals. Installed oil cups. All main components now function with just minimal drag. All slide valves now have smooth surfaces and slide very nicely.
will finish up over next few months for install into 60 inch trawler. Have a large chelston model boiler and large stuart boiler...will see which one works better. Chelston is coal fired and would need a big burner. Also have an external H20 pump and hand pump for boilers.
At one point I was considering a new crank . There is a gentleman in England who does cranks to order and was very fast to reply by email. If anyone needs one, he may be able to help you: type 'jim1kent ebay' into search bar. you will need ebay account to contact him.
