Guys, thanks for the compliments.
Brian, be careful what you wish for.
I should have stopped playing with this and got more serious about getting the engine running, but I'm having fun, and it's allmost finished.
For the rotor I found the cutoff from a hex something? I made, cant remember what it was right now.
Right size, and with a little help it would make an interesting and functional rotor.
First order was to make it look somewhat armature like, 1/8 holes drilled near the points and 1/8 brass rod Loctited in. Then turned to the proper circumference and a 1/8 button magnet routed in flush on the inside. Sorry forgot to take more pix.
Fairly critical for the glue up was getting the rotor centered in the housing, as up to now, the height was still adjustable via the loose collar.
I came up with this set up. It had to be moveable as the assembly would need to rotate into place, it worked well, but it took a while to get there.
The rotor is centered via the side shaft in a blind hole on the center of the housing.
This is the spring loaded clamping arrangement I came up with.
The timing device may still need to be shimmed in place when it is mounted on the wood base.
I figured I would need some sort of pointer on the gauge face, so this needle from a Fowler indicator fell victim. I bought a bag of these deemed unrepairable indicators, and they pretty much are, but I needed a needle and it was almost worth the five bucks I paid for them.
I gently drilled out the center insert so it would fit the new mounting screw.
I still needed some kind of numbers to put on the dial. No way I could paint the tiny numbers, and I was getting desperate to find something.
If I already didnt have one foot in Fantasy Land, I put both feet in.
I borrowed a worn out old Timex from my wifes defunct watches collection, shell never miss it, I thought.
At this point I was, kind of, waiting for a silly white rabbit with a giant pocket watch to come running thru my shop shouting Im Late, Im late.
Still needs an adjuster knob.
As a fair trade, gesture I converted the otherwise worthless watch into a Willie Nelson concert collectors piece. Shell love it.
A little brass knob added and I said fairwell to the rabbit and got back to getting the engine running (almost). As a parting shot I added this into the mix.
Not at all fuctional it should get a lot of people thinking.
