arnoldb said:Sam, getting a machine running that slowly is an achievement on its own :bow: - you should be extremely proud of that.
As to getting it to run even slower, well, I might just put both feet in my mouth, but it seems that the weight (counterweight?) on the beam could have an influence here if your valve timing is properly set - because of gravity. If you move the weight closer to the pivot point, or make it lighter, it should make for a more "equal" stroke.
Regards, Arnold
Arnold,
Thanks!
The position of the weight does indeed influence the velocity of the down stroke. I have moved the weight along the length of the beam and it seems to be in the sweet spot now. I have played with the valve timing eccentric and a small movement either way reduces the performance.
I'm thinking that I should add some mass to the outside diameter of the flywheel. This should increase the mass moment of inertia and stabilize the rotational speed.
