Buffalo_VR
New Member
- Oct 8, 2012
- 4
- 1
Hello Everyone,
I have searched and read as many things as I could about this and have not found a specific answer. Perhaps I simply missed the answer.
I'll preface this with, the engine I wish to develop will only be run on air, never steam.
First question; Port size. For air use is bigger better? Or are there other considerations, like sealing problems with large ports? Or is there a mathematical optimum? It seems the ports I see in pictures are relatively small with more than 1 port dia. worth of space between them. There is more to this question but it is dependent on question 2.
Second question: Port timing
I have read of 3 different timings.
(1) crank journal @ 90°, before and after TDC = full open port
(2) crank journal @ 120°(4+8 o'clock) before and after TDC = full open port
(3) crank journal is located so a right angle is formed between crank shaft, crank journal and cylinder pivot = full open port. Is one technically correct? Is one better for air?
Third question,
Slots for ports? Not in the cylinder, just in the body.
I was thinking that having as much duration as possible would be better than a fixed hole. Providing of course that there is no overlap.
I have not seen any examples with slots, so perhaps I'm missing the examples..or..I'm just missing things in general
Great informative forum btw.
thanks in advance
bvr
Third question,
thanks in advance
bvr
