Tin Falcon
- Jul 9, 2007
- 7,207
- 789
It depends on your definitions of a machinist. Is a lathe operator or a mill operator a machinist they do machining.This is the problem with modern day machinists, they want everything 'just so' and if it can't be bought, they don't want to know about it.
There are production machinists that make a single part over and over or maybe an operation or two on that part before it goes to another machine to get finished. Then there are job shop machinists.and CNC machinists. Last but not least hobby machinists.
In the industrial world time is money . If shop time is worth $120 per hour the boss would much rather pay 6 bucks for a insert cutter with three edged than use 10 minutes( $20) worth of time to sharpen a bit. the same goes for home made recipes. In the home shop learn and do as you see fit it is your shop. And if folks do not learn and use the old ways to some extent they will be lost forever.
Everyone here has his or her goals in the home shop.And in the home shop money may be time. Most of us work and are lucky to get 8-16 hours a week in the shop . and if someone wants to learn to build an engine they may not want to use valuable time to make tools. time making tools is not wasted if you like it and enjoy the time doing it, It builds skills and the money that could have been spent on a tool can be used on materials.
It is a personal choice. What is right for a retired guy with a well equipped shop may not be the best choice for a working guy just starting out.
Yes learning eye hand coordination is valuable . Learning to draw free hand and on the computer is also valuable.
There is nothing wrong with learning bench work or learning CNC.
Bogs I respect you and you opinion. what you do and how you operate your shop is likely the best way for you.
Each one here has to learn his or her own path in this hobby. Many people, many counties many perspectives based on life experience and choices.
And yes i need to admit any tool whether a file or a cnc machine is ony as good as the operator behind it.
The most important tool in this hobby is the human brain.
We are all here to share our experience and show options. Only the guy or gal at the other end of the monitor can choose what tools and technologies books etc go into the shop. Also what projects come out.
Happy and safe machining to all.
