Tony, first off I'm glad you solved your problem. The next thing is I refer to your post #278. Setup is the most important aspect of machining. Sometimes setup takes more time than the actual cut but as you have found out there is no substitute. The work around, drilling and reaming first, is OK if the part is small enough to do that but it would be nice to figure out why it was happening in the first place so that it could be avoided on something larger. A new sharp drill with equally shaped flutes should drill quite an accurate hole. It's usually when the drill has been resharpened that it wants to push sideways while going through the material. Anyway, the rest they say should be a piece of cake.
gbritnell
