lazylathe
- Aug 27, 2009
- 1,284
- 6
Hi All,
My last find was this Edgar T. Westbury Stirling engine.
It was seized and full of grime from sitting for many years!
After a thorough cleaning and oiling everything turns again!
Although it too will not run!
Turns over a few times and then stops.
I figure that the displacer rod is loose in the brass bushing as i can rock it back and forth.
This is the part is suspect!
The piston is a perfect fit. It will fall down on it's own but when i put my hand underneath
the suction is so great that i cannot move it in the cylinder.
I have concluded that air must be escaping through the space between the bushing and the rod.
Would you agree that this could cause it not to run?
I am battling to remove the hot cap from the main casting.
It has been together for about 30 years!
I need to remove it to get the displacer out and see what my options are when it comes to replacing the bushing.
I was laso thinking about maybe using an o-ring to seal it?? Any thoughts on this?
I still need to finish off some of the engine.
The burner plate needs some feet to be machined because the feed pipe is below the plate.
And also a chimney needs to be fashioned and attached to the back.
There are no drawings for this part so i guess it is up to the builder to sort it out?
Also would this be water cooled?
It has an air jacket around the cylinder and the plans call for it to be tapped to fit 1/2" gas fittings.
Also he has left the flywheels solid.
I will change these to spoked designs when i have some more experience!
Think they look a lot better!!
Another project on the go now...
Should be pretty cool when it works!
Any help or insights appreciated!!
Andrew
Andrew
