Regarding the 1.75 degrees on the rod. If you have a cad program to work by, or even if you can lay it out on a piece of paper, the center of the radius at each end is the center of a "hole" twice the diameter of a radius. So--best way is to start with an over-width piece of stock, determine where the four holes should be, and drill them thru. Then take a short piece of round stock the size of the hole and press in two short pieces about 1" long. Now set the con-rod up in your vice with the two pins resting on top of a parallel setting on top of the vice jaw. Tighten the vice and then remove the round rods and the parallel and the tool path will be truly horizontal. And it will be 1.75 degrees from the centerline of the rod. The problem with using a narrow piece of material to start with is that you can't drill a hole which is only partly on the stock.
