Okay--I haven't seen it done that way before, but it should work.
I am attempting to build this same engine. I have started but I'm not nearly along as you are. I do have a question about the gears. Would it make a difference if 14 1/2 pressure angle cutters were used instead of the 20 degree cutters? I have access to 14 1/2 degree cutters.
Hopefully I can make a little progress on the engine in the next few weeks. Thank you for posting all this information on your build. It has spurred me into building mine!
Mow
Changing the pressure angle may change the pitch diameter to accommodate the required necessary 60 teeth.
Larger pressure angles are for added strength and less undercut on small diameter pinions. According to Boston Gear,Ok, I will try with the 14 1/2 cutters and see what happens. I will post the results when done.
Thanks for all the help. I don't want to interfere with Werowance's build thread..
not sure I understand the folded over part
