I was a little busy this morning.I might be a little dense in this regard. But, is the arrow pointing toward the chuck on the lathe?
So, Hello again
Don't worry about questions, all questions are welcome !!
And it is not necessary for other engines, unless you are working with smaller sizes. No need for this engine, can do it with 2nd engine if you want - maybe...you will learn somethingFinished the cylinder, at least I think so. Used 400 grit and 600 grit silicon carbide. Feels and looks very smooth. No mirror shine, but from what I understand, not required for the Webster (please correct me if wrong).
Thank you. The measurements are allowing for a slight taper smaller at TDC. As I stated in an earlier post, it is difficult to measure with a telescoping gage. In any event, per my measurements, the taper is gradual from about .873" at BDC to 8727" at TDC. I think this may be a good thing.And it is not necessary for other engines, unless you are working with smaller sizes. No need for this engine, can do it with 2nd engine if you want - maybe...you will learn something
If the measurements are the same then : Great
Which lapping method did you use ?
