David: Have you done any tests or arrived at any conclusion on the effect of piston location (at TDC) has on operation. My latest prototype has a disc for a crank with threaded crankpin holes at .25". .375", .5" radius. By changing the position of the crankpin, I can select a .5", .75", or 1" stroke. Changing the position of the crankpin to a shorter stroke means that the piston is not going to the top end of the cylinder.
I also have a selection of connecting rods that put he piston at the top of the cylinder for each stoke length. So far, on my particular model, I seem to get the best performance at a .75" stroke length but the length of the connecting rod has not shown any significant effect.
This would appear to be contrary to logical theory in that you would have a volume of air in the cylinder at all times that you have no control over.
One other change I have made on version 2.0 is to change the coupling between the hot end and the power cylinder. On the first version, the two components were threaded into opposite sides of an aluminum block. Since this provided free flow of heat from one to the other, I have changed to the method used by the glass test tube constructors.
I made a new cylinder (1.25"OD finned with ,75" bore) with a ,5" long neck with two O rings and just plug one of the hot tubes onto the neck. The drawback to this is that I now have a minimum length of .6" restrictor unless I put the restrictor into a counterbore. The neck is currently bored .25" and I have three shouldered restrictors of different size .6" long that are just pushed into the neck Just another challenge since length of restrictor seems to be one of the unknown factors. Stan
