Vertical I.C. Rupnow Engine
Congrats David, looks and sounds fantastic!
James Fitzsimons
Well I have installed the new O rings kindly supplied by David Lloyd but although I am getting a good spark the engine does not want to start. Is there some sort of check list I can follow to fix the problem?
As said before--Pull the head off, put the heel of your hand over the top of the cylinder, and rotate the crank with your other hand on the flywheel. If the ring is sealing properly, it will be very difficult to turn the engine over with your hand sealing the compression completely. If that proves that the ring is sealing properly, then it almost certainly means that your valves are leaking. A test that I have made in the past, out of sheer desperation is to make up a dummy sparkplug with a hollow center that you can slip a rubber tube over. Make sure the engine is in the position it would be in with piston at top dead center, ready to fire, and submerge the whole engine in a bucket of clear water and blow your guts out on the other end of that rubber tube. If the exhaust valve is leaking you will get a stream of bubbles coming out of the exhaust pipe. If the intake valve is leaking you will get a stream of bubbles coming out of the carburetor. If the head gasket is bad, you will see bubbles escaping around the sides of the head. Make absolutely certain that when the exhaust valve is not up on the cam that there is .005" to .010" clearance between the rocker arm and the valve stem. 99% of first time engine builders who have the problem of the engine not starting have leaking valves. The engine absolutely must have compression to start. Is it sucking up fuel now when you try and start it? Is it firing at all? try some "quick start" ether sprayed into the carb while turn the engine over with your drill. HAVE YOUR FIRE EXTINGUISHER NEARBY!!! Put your mouth over the inlet spout of your gas tank and blow as hard as you can---does that make the fuel rise up in the line to your carburetor.---that little test shows that you do indeed have a clear passage from the tank up to the carburetor. Do all of that and report back. I damn near went crazy with my first engine build, the Webster, because of leaking valves. Do not despair. I have a fix for everything you may run into.---Brian
Thanks Brian. I shall try those things out today and report any progress.
Sorry Brian. Had a bit of storm damage here that's kept me busy for a few days. Luckily nothing too serious. I should be back to the engine Sunday or Monday.
I took the head off yesterday to check out the compression. Piston slides very smoothly and when I placed my hand over the cylinder it was impossible to turn the flywheel so compression doesn't seem to be the problem. Today I shall make a hollow dummy spark plu and give it the under water leak test to find out where the air leaks are.
Odds are better than good that your valves are leaking. I absolutely could not make valves that didn't leak (well actually valve-seats that didn't leak) until I built a copy of the magical George Britnell seat shaping device. It is not difficult to make, and it doesn't take much time, but it yields almost magical results.--If you have any questions about it, ask me. You can use O1 steel which is hardened by quenching in oil, or you can use W1 steel which is hardened by quenching in water. Make sure you sharpen it before you harden it, as you won't be able to sharpen it afterwards. There is no need to "temper" it after hardening it, just don't drop it on a cement floor or it will shatter.---Brian
One more thing Herbie--I have found that if you can't get the valves to seal after lapping them properly, it is almost impossible to go in with this tool and "reface" the guides and make them seal. It is quicker and less frustrating to just make new guides and install them, then use this tool first and then lap the valves into the new guides. You can try to save your existing guides by refacing them with this tool, but I've never had any luck doing that. The tool will last virtually forever.
Thanks Brian. It looks like I will be making a couple of new valve guides. On submerging the engine and blowing air into the cylinder a steady stream of bubbles came out of the carby. Only a few out the exhaust.
Thanks Brian. Making this tool is my project for this weekend.
Hi All,
Made a start, will be a slow build, material is the biggest problem, will use a mix of imperial and metric.
Cam and drive done. Cam cut with a fly cutter. Still have to drill and tap for lock bolt and grub screws.
Andrew
Ghosty--welcome to the gang. This is a fun project, and a good runner. There are at least three other folks down at your end of the planet building this engine, and if you get hung up on anything I will help however I can.--Brian in Canada--Your gears look great.
Hi All,
Got the crank and the push rod and guide done, drilled cam gears for grub screws and lock screw. Found a supplier for the frame alloy block, also ordered some other sizes of alloy bar for other jobs. Should be sent tomorrow. Ball bearings all ready on the way.
Will finish pushrod off after the bearings arrive.
Great work Ghosty. I don't know why it is, but my engines are always a big hit in the land down under. I get more builders in Australia, Tasmania, and New Zealand than I do in Canada or USA.---Brian
Hi All,
Got two delivery's today, some 6mm hardened steel rod, and some ign magnets, and repair HT lead kits. I have several electronic ign's left over from my RC aircraft days.
Won't get much done tomorrow as I have a specialist 1 1/2hrs away at midday, will most likely be there all afternoon.
