Hello all,
I have a little project I'm working on and I've already ruined a nice block of aluminum due to a mistake when drilling a long through hole. needed to drill thru 5" block of 6061, and I don't have that much drill length, so I tried to reposition and drill from the other end and meet in the middle, ended up about 1/16 off.
Is there any reason I can't use a block of wood to build a prototype of my project? Would my endmills cut the wood properly? Would the wood ruin my endmills in some way? I'd just like to be able to go thru the setup and machining with the wood and see that my setup will properly work before cutting up another 1.5"x3"x5" of 6061. :wall:
Thanks
Thanks
