That is the correct solution to resize mis- sized threaded holes. Especially into the combustion chamber, an oversized threaded plug with a sealant. This also works if you need to relocate off your original spark plug position or change the spark plug angle into the chamber when you redrill and tap."......I've been thinking about making my own threaded insert to repair the damaged sparkplug threads on one cylinder head. It looks like I can make a piece 3/8" outside diameter with 3/8"-16 thread and a hole through the center with a 1/4"-32 thread, tap a 3/8" thread into the cylinder head and screw in the insert along with some J.B.Weld on the threads.".......
Do those pushrods follow the plans as far as diameter?Today I was busy like the beaver. I made four rocker arms, which are just about at the limit of "littleness" for me to make. Then I made four pushrods, which are posed for the picture, but I haven't actually made the cams yet.
Anyone who single point cuts a thread when they could have used a tap or die has waaaaay too much time on their hands.A die? Blasphemy! He has a lathe.
This is true provided you first have the die you need and second have a way to hold and start it perfectly square to the part being threaded. Then you have to fiddle with the adjustment on the die.Anyone who single point cuts a thread when they could have used a tap or die has waaaaay too much time on their hands.
The downside to spiral taps is that in my experience they are easier to break than a standard tap (also they don't seem to work so well in small sizes). Spiral point is good for through holes but awful for blind holes. And of course fluteless is useless for brittle materials and plastics. Horses for courses, as they say.You don't need a fluteless tap for that. Just use a spiral flute or spiral point. First lifts the spiral of swarf out the top of the hole, second pushes it forwards and is used for through holes, neither are backed off to break the swarf. Very good for hand tapping not just machine tapping. And works in all metals.
Same with Dies, if you get a "gun nose" one that will push the swarf forwards.
