vederstein
Must do dumb things....
- Feb 26, 2011
- 932
- 776
Here's a cross section of the engine at its most advantageous torque. As you can see from the free body diagram, the the torque "arm" (L) is only 0.066". So the torque applied to the crankshaft from each piston is:
T = L * F
T = L * Press * A
T = L * P * pi*r^2
T = 0.066 * 55 * 3.14 * .313^2
T = 1.1 in-lbs
.187
If the piston is offset from the camshaft, the "torque arm" can be significantly increased but it's to the detriment of higher cam forces on the return piston stroke. In the illustration below I offset the the piston 0.188" which is the centerline of the cam at 90 degrees. You can see here that the "torque arm" goes from 0.066" to 0.188" which would change the applied torque from 1.1 in-lbs to 3.2 in-lb at the same pressure, a 290% increase in torque which would decrease the air pressure requirements from 55 psi to a more reasonable 19. The stroke would increase significantly as well.
Based on this analysis, it appears the biggest improvement would be a change in geometry. But I'm not going to re-make this engine. Remember back from the beginning: if it runs, it's a success.
I'm always trying out new ideas on this hobby. I can leave it to other to optimize...
...Ved.
T = L * F
T = L * Press * A
T = L * P * pi*r^2
T = 1.1 in-lbs
...Ved.
