doozer
New Member
I new to machining. So far I have built a wobbler and Tubal Cain's spool valve.
I would like try building a twin cylinder. Haven't found any plans I like. I was going to take a single cylinder design and join them on a single crank.
Is the crank 180 degrees apart for a single action and 90 for a double acting wobbler? Would the exhaust and intake be in the same location on both cylinders?
Would a twin spool valve piston crank be 180 degrees also? I may still use an eccentric for the actual spool valve as you can adjust it.
