peterl95124
- Feb 22, 2020
- 526
- 345
how do you know its not one of the other "usual suspects"
compression (rings and valves sealing) ?
valve timing ?
ignition (getting a hot spark) ?
ignition timing ?
carburation (needle valve, throttle, gas flow) ?
after going through "all the usual suspects" I recently solved a non-starting
problem with some automotive starting fluid (AKA ether), turns out my arm
is no longer strong enough to flip the prop fast enough
FYI Atkinson Differential engines are notoriously hard to get running, that one's not your fault !!!
valve timing ?
ignition timing ?
