- Sep 19, 2015
- 274
- 80
Hi all.
Just started building a twin cylinder sort of loosely designed on Longboy's engines, although already I can tell mine is going to be ugly. It's going to be as simple as I can make it and hopefully it will run.I have bought a slitting saw and boring head for the mill neither of which I have used before so I will learn something maybe. The crankshaft is bolted together through a thin section bearing 17x26x5mm with four m3 bolts ....make that three just broke a tap off in the last hole :wall:not going to get that puppy out but three will hold even two would I think.Just a little rubbing so I have taken a whisker of the back of the webs . Hoping I won't have to use a large flywheel as these webs are thick and heavy 1020 steel .
