I am in the process of building a true fuel injected engine by trial and mostly error and have made some progress. The basic engine is completed being a water cooled single cylinder 40mm x 80mm stroke and a compression ratio of 20 to 1.
My problems started when I designed my first fuel pump. I wanted to copy the CAV scaled down. At this time it has proved to be too difficult and has been put to one side. Note, all of the machined parts worked well but the cutout on the piston has been my down fall. I have now designed fuel regulation via a needle valve. Most of the parts have been made several times to obtain the required accuracy with me learning along the way. The injector has had six versions, the last failed at 1500 psi taking a lump of concrete out of the workshop ceiling. I am now on version seven and I hope all of the errors in design are behind me.
My question to the Forum, is there anyone who is or has built a true diesel and would be willing to comment on the issues surrounding fuel pumps, injectors and overall construction issues.
Bruce Weir-Smith
Western Australia
Bruce Weir-Smith
Western Australia
