Greetings once again, fellow Earthlings....
Lo and behold, I've finished up my engine at long last! Here are some final pics to show how I got there. This is some pretty basic stuff but it was mostly all new for me. Did I mention it runs like a champ? woohoo1
I'm working on the video and should have something to post by the end of the weekend.
Taking a cue from Metal Butcher's build, I carved out the steam valve before separating it from the larger piece.
Then I flipped it over and v-e-r-y carefully milled out a .030" cavity.
Next on the list was the pack nut. A few weeks ago I had no idea what purpose this served. It was easy to make and fun too.
Started by turning down some hex rod, spot drilled then followed up with a thru hole drill.
Threaded the end to 1/4-40 then parted off.
I had to grind off the end of my new 1/4-40 tap so it would thread into the steam chest far enough. A test fit and photo op shows I'm ready for the next step.
The valve rod was a logical choice for the next part. Starting with a pretty long rod of brass I had to set it up using a live center on the lathe. First I turned it down to the diameter required for threading the valve nut.
Then I turned the end down to the diameter needed to allow the die to pass over and to match the hole in the far end of the steam chest.
Threaded the rod for the valve nut.
Threading ready for prime time.
Into the collet block and mill for a few passes to cut the slot in the end.
Flip the collet block (gotta love'em) around to drill the linkage pin hole.
Tin Man likes it, so do I.
Made a plexi glass cover for the steam chest but didn't get any pics. It was too easy...
Time for the inlet nipple, an easy process.
I called to Dinky my dog and had him balance it on his nose so you can get an idea of the size of this thing. It must weigh 5 pounds!
After almost 5 months, one or two parts per week, at last it's here! Thm:
I would like to thank all the contributors to this forum for their helpful advice and comments in general for helping me complete this engine. :bow:
Stay tuned for the video!
-Troutsqueezer.
