Thanks Guys.
Sure enough, it's been a week and I finally finished the connecting rods. That dang American Idol is keeping me from my work shed! ;D
I started by cutting and milling to size two brass bars then drilling two holes in each for a 2-56 tap to hold the caps on. Then I cut off the caps using a slitting saw. Having worked with wood for many years, I'm used to saw blades coming to an abrupt stop when they hit metal so it was interesting to see this slitting blade cut through the brass like butter.
After the caps were cut off I tapped the holes in the connecting rod and drilled clearance holes in the caps. Then I drilled and reamed the crankshaft hole and the hole for the wrist pin. Next I clamped it into the lathe using a four jaw.
It starts to take shape.
The real deal. I still need to remove the circles on the rod diameter. No sharp edges left here, sorry MB and Marv! My next engine will have less bling and more sharp edges. 8)
This evening I assembled the pistons, crankshaft and cylinder and found there to be a few clearances that need tweaking. Hopefully I'll have time to do that tomorrow, then I can bring it into work, rotate the crankshaft and impress the boys.
On a side note, I'm anticipating some soldering on this model so I fashioned a hearth of sorts. While at Home Depot a few days ago I noticed a damaged piece of Hardi Backer board in the corner. They sold it to me for two bucks. I cut some small pieces from that and placed them into an old well fuse box I had hanging around. We'll see if the rumors are true that Hardi Board works for this.
I welded some coupons on the bottom to decouple the hearth from the bench even though it has 1/4 inch steel plate for a top.
-Trout
