cfellows said:I usually try to get down to within .001 of finish size with the carbide tooling. Then I use a file at 70 -100 RPM to smooth away the carbide marks. Finally, I use a strip of 400 grit wet or dry sand paper at a very high RPM to get the finish OD.
When I turn the valve stem I take the diameter down a quarter inch section (or less) at a time, .020" per pass to get to a little over finish OD.
It will come together Chuck! I saw your engine in the FAME Gallery under "work in progress" and made a future reference note when I was developing intrest in I/C. I still hold that open crank bar stock twin in mind. Good luck with the sealing! Dave.cfellows said:My relationship with internal combustion engines may be coming to an end. I dusted off this project which I had started (and almost finished) a couple of years ago. Never had this many problems with an engine before!
Chuck
