Tony Bird
Senior Member
Hi,
Today I continued making the cylinder and fitting it to the engine. An aluminium plug with a hole the size of the piston rod was used to line the cylinder up with the beam. I hope the the photo graphs show how the cylinder was made. Any question please ask.
The Hexagonal brass tube was cut to make the base of the cylinder.
The base was soldered to the cylinder tube and machined.
Steam passageways were drilled.
The cylinder fitted to the engine.
As of 5.00 pm this evening. There is still quite a bit to do fit the K&S brass tube liner, cylinder covers and piston have to be made and the valve connected to its actuating rod. Some pipes will need to be fitted to the port block/cylinder support and some tidying up of screws etc.
Regards Tony.
Regards Tony.
