My main idea was to build a high rpm, fast acting, self starting steam engine with good primary and secondary balance and variable cutoff for efficiency.
High rpm steam engine is a question about how much the flash boiler can produce an amount of steam per minute ...
Jens, I am afraid your thinking on this is coming over as very muddled. You are right that the power output of the engine depends primarily on the power output of the boiler (and secondarily on the efficiency of the engine). However, you can get the same power output with a small, high-speed engine, or a with larger, lower-speed one. Relative engine to road speed depends on gearing. Personally I would go small.
jazz256, if you want a high-speed engine, why do you persist with talking about such a long-stroke configuration as 2" x 4.5"?
The car had a v twin double acting uniflow engine that had a maximum rpm of 4000. Can anyone explain this?
Question, I found an early proposed engine idea I had for the car I did a while back. My question is would a tandem compound steam engine work in a steam car?
The steam engine has very short stroke at 2" with cylinder bore 2 3/4" hence the steam engine has maximum revolution without load with a steam working pressure at 1200-1400 PSI.
Does anyone have anymore information on the Pritchard engine? I think it would make an interesting model if I ever get the time to get back to the shop.
Forgotten to write in early post.. Do not have too big steam engine is to be believed that it performs best when you do not take the size of the boiler. Horsepower is determined by the boiler that produces steam flow / pressure steam engine will provide the best effect. Thus it is not the steam engine that determines horsepower. Too little steam boiler -> steam engine loses power.
Another resource for all the things steam people have tried is Tom Kimmel's steam museum. It will take several days to look through the various papers on his web site. Chuk Williams converted an old Force 3 cylinder outboard engine to steam for his Bonneville record attempt. Others have converted various Mercury outboards. To get an idea of what the engine for a 150 mph streamliner looks like, see below.
Lohring Miller
Chuk wrecked his streamliner on its first high speed pass. He was going over 140 at the time. From Chuk:
"There has never a question in my mind regarding the stability of the streamliner-it's always felt very stable and tracked like it was on rails. Until this time at the Flats-that is. When we did the first shakedown runs at Bonneville in October '12, the salt was hard and dry, the vehicle tracked straight and was very stable.
This time the track conditions were very different....as in-wet and slushy. The handling of the vehicle was very different, and very difficult. Nonetheless-the track conditions were not to blame for my accident.
The blame for the accident lies squarely on my shoulders. I packed the parachute-I diverted my attention to the parachute release when it didn't function as expected-those two things are the reasons for the accident. The track conditions were a contributing factor, but if either one of the two reasons above had functioned as they should have-the accident would probably have never happened. I had control of the vehicle all thru the run-right up to the 5-1/4 mile-when I diverted my attention to the parachute release."
"Yes there is a video, taken from about 3/8th mile away. The photographer was Randy Maxwell, affiliated with the guy who had the big truck with a V16 with quad turbos. He was getting anything that looked interesting, and part of that included my run-along with the accident.
https://www.youtube.com/watch?v=hbHzR3LGMtM&feature=youtu.be
The video is 5+minutes long....Randy had the video running as we started the vehicle at the start line in prep for the run. You can hear the radio announcer thru out the tape, calling off speed as we progressed down the track. Finally, at about the 2:10 portion of the tape you can see the streamliner enter the video on the right.
As you watch the streamliner progress down the track-moving from right to left-you'll notice that as it passes the last two black markers(they're the 1/4mile designator) the image of the vehicle changes and you can see a fog of salt being thrown up....that's the beginning of the end! Watch closely, and you'll see a small change in the image again-with more salt being thrown up. At this point the vehicle makes a ninety degree turn away from the camera-this is when it became airborne for approx 400 feet-you see lots of pieces flying off/clouds of salt obscuring your view because the vehicle is going away from the viewer. If you pause and restart the video at this point(for a split second at a time)you can see the vehicle go end-for-end at least once, before finally rolling to a stop to the right of the body pieces. If you listen closely during the crash you will hear the violence of it. Then you will hear-and see-the emergency response teams doing their thing. "
Lohring Miller
Thank you for the video link wonder what he will do if he has another attempt.
