peatoluser
- Apr 19, 2010
- 174
- 2
The longer pivot arms in the curved links have a collar on the end to hold the reversing link bearings in place. decided to use taper pins (1/16") to hold these in place. not having much luck with cross hole drilling in the drilling machine, I decided to mill a V-block to fit the lathe. used a combination of 6 flute countersink & 1/16" slot drill to produce a vee groove in a block clamped to the cross slide.
here's the block beeing milled
and the small journals (5/32" dia.) being cross drilled .I loctited the collar onto the shaft to hold it in place, then after I'd drilled and reamed the hole disassembled with heat, before soldering onto the link.
the v-block worked so well that i ended up making another, but used a 1/2 countersink to produce a bigger vee.
With all the valve parts made, I thought I'd have a trial assembly of the shaft and base. here it is.
Instead of making round oil cups for the main bearings, I decided to try and make them square. A bit like the large oil boxes on full size engines.
Forgot to take photos, but I milled an oval slot in some brass bar using a similar set up to the way I'd drilled the reversing link bearings.
the lids are only a push fit. I tried milling these from solid using the vertical slide. got into all sorts of difficulty with size depth of cut etc.
so bought some solder paint and made them from scrap pieces of 18g brass. It may be an expensive way to buy solder , but a touch of the flame and they were done. I guess it pays to at least think of a couple of ways to do a job before cutting metal
I guess the next job is to make a start on the columns, but befor that, I've agreed to walk the coast-to-coast route. the daft things one agrees to do when drunk ;D. 2 weeks without any shed time. how will i cope!
thanks for looking
peter
![VCUTTING.jpg](https://proxy.imagearchive.com/060/06086e8be6546eaab4423157b3a3e840.jpg)
![vblock.jpg](https://proxy.imagearchive.com/3c4/3c43f8efcc41f16e0094a631c90785c8.jpg)
![trialassembly.jpg](https://proxy.imagearchive.com/feb/feb6a740afb5a6054f718491a211367a.jpg)
thanks for looking
peter
