maybach_man
- Oct 28, 2012
- 22
- 9
A good page for freecad tutorials
https://www.youtube.com/c/Adventuresincreation/videos
Hmmmmmm - - - some effort - - - - nice understatement there!!!!!!!!!!!!!I use and am sold on FreeCAD. It's free and widely supported. Latest version is 0.20. Takes some effort to learn but it's worth it.
And maybe that's the rub for me.I like fusion also even with the messes it’s created .
I think the biggest thing is to consider that the programs only connect the shapes and lines it’s not intelligent . Many guys and gals can’t seem to get old school drafting out of mind . I YHINK most programs can generate drawing s some even do automatic dimensioning on drawings. But the bottom line is to begin thinking in terms of the finished product . Essentially you are creating this using solid shapes modified by cutting or adding features . You manipulate various icons to achieve this most have some kind of tool box that provides fasteners hole counter bores all ready for you to insert. . For example you could select a clearance hole through then a counterbore into the curvature of a ball bearing. It would not be fun to create in the shop but not impossible using some nifty machines in a work invironment you could expect a call from the shop asking if you really wanted this. What I’m getting at is you create the object using the cad tool or icons and text . Some programs are more powerful in that they may allow analysis option and wild coloring Woods can be colored shaded given grains . This is exotic area. I’m not real big on it unless it’s for some presentation. I usually thought of this as needless use of computer space. You design into the parts . Parts are made to the machines capability . The cnc shop will determine if equipment can do the job . If not they come up with a there is a lot more to it but others can add comments too. solution so it takes the machinist out of the picture. .
That's engineering, not 3D CAD.What I would like is help with material quantities and where's the best place to put a support or how do I support this long whippy thing so that I can do x or y at this speed.
I organize like this: Caffeine in the morning. Do something in the garage or outside. Take a nap in the afternoon. Do something more before dark. After dark, I may watch some krap on tv or play computer games. when filled up on that or more likely while watching some krap on nutlix, do some drawing on either something I am working on or something I intend to work on.And maybe that's the rub for me.
I can usually visualize what I want to build - - - that's not something I need help with!
What I would like is help with material quantities and where's the best place to put a support or how do I support this long whippy thing so that I can do x or y at this speed. Except then in these 'wonderful full featured' 3D CAD programs - - - well they don't have a wide enough nor complete bolt/screw/pipe/tubing/material availability and then I am supposed to work around that and then trying to find one's way through the minefield of 'have tos' when the breadcrumb dispenser is broked - - - well - - - I can, using paper and a writing tool (sometimes even less) create a 'physical' sketch in moments - - - and that's enough for getting the job done. Just sharing with someone else or for posterity - - - well then that's the rub.
Too many things to do and the time to get things done seems to be getting less - - - not more.
Some times machining capabilities . This leads to issues in the shop making chips as we say . This is where you can design yourself into a hole very quickly . It’s a easier to delete a feature on the screen before it hits the shop and before a piece of unobtainium gets scrapped out
Have pick a cad program.I have been building and designing model engines now for quite some years and have been modelling for over 65 years. I have designed from scratch about 11 model diesel engines and built them and they all run - and have had a couple put on CAD by kind fellow enthusiasts.
I would like to have a go at learning CAD enough to make at least 2D drawings and hopefully in time be able to do 3D where the design can be rotated, but realize baby steps first..
I was reasonably good at maths 60+ years ago when at school - but sines and cosines etc mean zero now.
I am happy to spend some funds to get the right programme but there seems to be quite a number of them - so thought I would pose the question here and see if there are others like me that had the desire to conquer CAD and have succeeded.
If that is supposed to be a solid piece of metal then it is not handling things well with those lines where you have extruded separate sketches, should not be there on a "solid" pieceEdit*
FreeCAD has come a ways since .18
20 minutes of fooling around and it seems to handle slivers and overlapping features quite well.
