I would assume (you know the assume statement) that using sufficient ventilation would be going on when firing a furnace due to the high possibility of CO in the flue gasses and in most cases more heat then a non ventilated environment can handle. The exception to this are those that are using electrical heated furnaces such as electrical kilns for melting. The need for high ventilation during drossing and degassing is still required.
